POLL: Anyone Having Trouble Posting Pictures on AAPK????
Tell us how we are doing, report problems, voice your concerns, and all that stuff... All input is appreciated and will be taken into consideration.
Hukk
Re: POLL: Anyone Having Trouble Posting Pictures on AAPK????
Post by Hukk »
MILLER BRO`S wrote:This has been a problem for a long time. I am having trouble posting pictures, and staying logged in! :x
Anyone else having the same problem, from reading different posts it seems I am not alone.
I have contacted Bryan about it. If you are having problems post it here!
M.B.
MILLER BRO`S wrote:Hukk, Wullie, All,
You may have something there. I know I am out dated using a 3.5" floppy, but my old camera takes such good pictures I can`t bring myself to get rid of it! To answer your question yes, I have a dial up internet connection. I also store pictures in "my documents", and if I try to upload from there I have problems as well. Recently I cleaned my computer of all the old junk that usually slows things down, and it has had a good affect. It has helped matters but not cured everything.
I may need to get DSL and a new camera, but will that cure the constant "signin" problem ::shrug::
Thanks to everyone for your help and input ::tu::
M.B.
Staying logged on with a dial up. ::hmm:: Well, that makes me think you have a time out error. I remember back when I used dialup (around 2001) that I had the same problem. I checked the default setting on my modem that I had been trying to send a large 4 Mb file. I finally reset the modem timeout setting to 5 minutes and that solved the problem. The "potential problem" today is that the server that AAPK is on may have a less than 5 minute timeout - it may even be just a minute but that should be enough time if you can get 25 pictures on a floppy because that makes each picture about 56k which is not all that large.
There should be more than one phone number for your dialup from your ISP. Make sure you use as many as you can - local of course. I like to have the dial up set at 115200 as my maximum port speed. It's been a while since I've played with dial up though.
Another thing to check is how much RAM (memory) you are using. Hit Ctrl-Alt-Delete (same time) to start the task manager and click on the performance tab. I see that I am using 1.31GB and that is 75% of my physical memory. If you go above 75% of physical memory - you eventually lose speed. 90% will present problems! I will be adding RAM soon. All those updates from Microsoft sure add up after a couple years. Since cleaning has helped some this may be an area to look into. If don't have enough RAM - eventually you will be using a section on your hard drive called the page file. You will be very slow because RAM speed is very fast compared to a hard drive that may be turning at 7500 RPM or so at best. On one PC I have SATA (serial ATA) hard drives that run at 12,000 RPM and that is a FAST beast. I built that in 2003 and it is still faster than most of the PC's that you can buy today.
Well, there are a few ideas for a dropped signal. If I can help with this techie stuff just let me know.
Hukk
razor1
Post by razor1 »
No problems to report here ::tu:: I upload mine from a folder in my documents with no trouble whatsoever ::nod:: Razor 8)
Praise the Lord and Pass the Ammo! I live in my own little world. But it's OK. They know me here!
junebug
Post by junebug »
had probs all day today ta get my pics up in the tradein' forum!!!! i think 2 or 3 ppl said they had probs last week in the tradein' forum too....?????????????????? ::shrug::
- Junebug 2016
garddogg56
Post by garddogg56 »
What's up with the new pixel size this is the first time it has happened to me????Did something change??
Location: The middle of the top of a bastion of Liberalism.
Post by jerryd6818 »
Hey, dogg. If this is what you're talking about, I think I'm pretty safe in saying that's caused by Bryan putzin' around with the software and that's caused by a parameter setting in the forum software. We had a similar problem a few weeks ago when he moved the forum to another server and we had issues with image sizes until he changed it. Relax, he'll get it. ::tu::
garddogg56
OK thanx Jerry ::handshake:: I spent an hour trying to change pixels ::uc::
garddogg56 wrote:OK thanx Jerry ::handshake:: I spent an hour trying to change pixels ::uc::
dogg, try this.
Adog
Post by Adog »
Yes it's not even easy after about 75 min. I did post 2 pictures and I have no idea how I did it . Tried to post some last night and after a hour I gave up. I don't have a computer am using a android phone. Any tips on how to get pictures posted from the phone please let me know what to do. Thanks Adog
gsmith7158
Post by gsmith7158 »
Adog wrote:Yes it's not even easy after about 75 min. I did post 2 pictures and I have no idea how I did it . Tried to post some last night and after a hour I gave up. I don't have a computer am using a android phone. Any tips on how to get pictures posted from the phone please let me know what to do. Thanks Adog
A dog I have noticed in the last few days that I can only post two pics at a time. I think it has to do with the resolution size of my pis. Try reducing the resolution on any new pics you take from your phone. If the pics are already on your phone you may have to resize the pixels on those with a resize app.
Greg
PROUD MEMBER AAPK, NRA.
orvet
Post by orvet »
Guys, this is a very old topic.
If you notice the OP is May 2009, over eight years ago.
We've changed servers at least twice since then and change the whole operating program as well.
I just uploaded for large unedited pictures have a Camillus Streamline that I need to repair.
If you look close you can see the celluloid is starting to dimple at the prongs near the bolsters. This is a sure sign that the celluloid is shrinking.
I pulled the celluloid off to prevent damage to the knife. These pictures are taken by an eight megapixel camera with no editing. The file size of the first picture is 3.2 MB, the second is 3 MB and the third is 3.5 MB. These pictures uploaded with no problems.
orvet
Post by orvet »
From my Android phone
orvet
Post by orvet »
I hadn’t really posted from my phone before but it was easier than I thought.
This is the sequence of steps I followed posting from my Android phone.
My phone is an LG Stylo II Plus.
1- Hit the post reply button
2- I posted a line of text.
3- I hit the attachment below the text box.
4- Hit the add files button.
5- Choose the camera icon.
6- Take the picture.
7- Click okay.
8-I placed the cursor below my line of text and pushed the Place Inline button.
9-I press the submit button
If you haven't discovered it yet, there is a forum with a bunch of tutorials on how to do stuff like this. It's here highlighted in blue. If you're having trouble doing something, always look there first. If what you're trying to do isn't covered, send a PM to me and I'll try to whip up a tutorial on the subject.
In there is a thread named "Posting Pictures From A Smart Phone".
That thread is here: viewtopic.php?f=98&t=48561
Try it out.
gsmith7158
I have dropped my phone on numerous occasions lately. That could be my problem. 8)
Greg
kootenay joe
Post by kootenay joe »
I cannot get my pictures to load today. I see an 'Alert" ? triangle and when i click on it get this message "Error parsing server response".
Anyone else having this problem today ?
kj
orvet
Post by orvet »
Apparently the server was down last night. I don't know exactly what happened, I have not had a chance to talk to Bryan yet.
I am on my Android phone and the display is not right in Chrome yet. I need to try Internet Explorer and Chrome on my PC and see if they are working properly. Hopefully I can permission will be helpful to Bryan.
semroc
Post by semroc »
Dangit still can't post pictures. Can't get em small enough. I hate complaining because it's such a great forum but I gotta show off my old Shapleigh. Lol. Any suggestions? Thanks y'all.
It's important not to think too much about what you do. Lee Marvin
New_Windsor_NY
Post by New_Windsor_NY »
semroc wrote: Fri Oct 11, 2019 12:10 am Dangit still can't post pictures. Can't get em small enough. I hate complaining because it's such a great forum but I gotta show off my old Shapleigh. Lol. Any suggestions? Thanks y'all.
Yes. viewtopic.php?f=18&t=64045
garddogg56
Pics are a no go for me on my android. ::undecided:: :x
glennbad
Post by glennbad »
I seem to be having an issue trying to upload pictures. I keep getting a error that it couldn't verify the dimensions of the image. Anyone else encounter this?
Mumbleypeg
Post by Mumbleypeg »
How’s this? Seems to,be working okay for me.
First picture from my cell files, second from my cell camera.
*Edit- no issues here.
glennbad
Post by glennbad »
Hmm, that worked...
Papa Bones
Post by Papa Bones »
I am a new member. Posted a few photo's with no problem. Now, when I try to post a picture It shows a yellow triangle notification and says it is unable to determine file size, and the post in line button does not appear. I also tried to just drag and drop, but it still will not post the photos. I've not changed any settings. I even checked my firewall to see if something had changed.
Is there any settings in my member profile that I should know about.
Any help would be a appreciated.
Smitty
Papa Bones
Papa Bones wrote: Fri May 01, 2020 2:53 am I am a new member. Posted a few photo's with no problem. Now, when I try to post a picture It shows a yellow triangle notification and says it is unable to determine file size, and the post in line button does not appear. I also tried to just drag and drop, but it still will not post the photos. I've not changed any settings. I even checked my firewall to see if something had changed.
O.K. I am going to answer my own statement. I was reading in the post photos again and it said the format it would take was .jpg and .png. Mine have been edited in .jpg So I went back to my photo editor and re-edited a couple of my photo's and saved them to .png format. A couple of Case 07 pattern knives.
I then went to the thread I wanted to post them in and they posted with no problem. So for some reason the system was having a problem determining the size of the .jpg files. So anyone who may have this problem, try when you edit your photo's to save them in .png format.
Smitty
Return to “Suggestions, Questions, Comments, Concerns, Alerts, Etc...”
