Anyone Collect Axes & Hatchets?
A place dedicated to swords, hatchets, throwing knives, oriental cutlery, tomahawk heads and more. Anything you do not consider to be 100% traditional knife is welcome.
rarefish383
Re: Anyone Collect Axes & Hatchets?
Post by rarefish383 » Sat May 18, 2019 12:53 am
WOW, that plumb is cool. Sorry it took so long to get back. I'm putting a 12X40 building on my property in WV. I've had to drive 2.5 hours each way 7-8 times in the last 3 weeks, just to point and say put it there, to the contractors.
Bfeldman
Post by Bfeldman » Mon May 20, 2019 12:00 am
Rare fish-Isn’t that Plumb a beauty? That sounds like a lot of work for a small structure.
Here’s the HB after a cleaning, oiling and sharpening. I think I’m going to sell it on to pay for the rest of the collection.
Bfeldman
Post by Bfeldman » Sat May 25, 2019 3:33 pm
Wooo doggie am I excited. So yesterday I was running some errands and saw a sign for an estate sale. After poking around I found my way to the garage where I noticed a mattock and axe. The mattock was in good condition but nothing special. The axe was quite rusty but a quick glanced revealed an older style embossed stamp, so I knew I was onto something. I stopped examining it so as not to arouse attention, paid the $8 and took it out to examine it. Imagine my surprise at what had found!
It’s on a replacement Dunlap handle that someone had covered in fiberglass on both the eye and below the head. I assumed was cracked, but after removing most of the fiberglass the handle appears sound. Unfortunately, whomever replaced the handle seems to have used the fiberglass to secure the head to the handle and the resin is in the gaps between the handle and head in the eye.
I’d like to remove the head, clean it and rehang it properly on the same handle. Any suggestions for getting the fiberglass resin out without damaging the handle or head?
Doc B
Post by Doc B » Sat May 25, 2019 3:35 pm
That's a very cool looking axe head!!! ::tu:: ::tu:: ::tu::
New_Windsor_NY
Post by New_Windsor_NY » Sat May 25, 2019 6:18 pm
I don't collect axes or hatchets, but these 2 have been in my family forever. The one WITHOUT the handle has no stamp or markings of any kind (that I can find). The one WITH the handle is marked STANLEY MADE IN U.S.A. I'm not 100% sure, but I think
this was my father's when he was a lineman for N.Y. Telephone Company. If so, then 1946 to late 1950s? He could have obtained it later, but I would have no idea when. ::shrug::
edge213
Post by edge213 » Sat May 25, 2019 9:04 pm
I don't really collect hatchet, but I have a few.
I got this one mainly because I collect Keen Kutter items.
Any info would be nice. Such as what is this style called?
Bfeldman
Post by Bfeldman » Sun May 26, 2019 3:40 pm
Doc B-Thanks. I’m still a little giddy about that find.
New Windsor-That’s definitely a lineman’s Hatchet so it would make sense that your dad picked it up when he worked as a lineman. Stanley made a lot of them for Bell and I believe that those all have a Bell Systems stamp on the opposite side. I wonder if yours has a stamp on the reverse.
Edge213-You have what’s known as a hewing hatchet, used in finishing logs into timber or even more refined work.
rarefish383
Post by rarefish383 » Wed May 29, 2019 11:13 pm
Bfeldman wrote:Rare fish-Isn’t that Plumb a beauty? That sounds like a lot of work for a small structure.
39930C8B-F343-478E-B67E-CE68C5176A6F.jpegCF141AFA-B3E1-475D-91AC-C2D79BE45688.jpegC43C4CA0-6A89-49C6-B70D-4151BC452CEC.jpeg
rarefish383
Post by rarefish383 » Wed May 29, 2019 11:19 pm
For some reason I was having trouble getting pics to post. My problem is my drive is over a mile and a half long with sevearl other farms drives off of it. I had to get the building manufacturer to see if they could get the building in. Then the local quarry is just a few miles away, just over the line in VA. They only have 4 trucks they can run into WV. WV requires "Apportioned Tags", and there trucks with them are quad axle dumps. He couldn't cross our cattle bridges. The guy that is doing the grading has the same problem. The only truck he can haul gravel on doesn't have Apportioned Tags. Finally found a WV guy that could do it, but he had to make two loads with his smallest truck. Then I had several trips to widen the drive from about 7' wide to 14' wide, the entire length of the drive. It will be all finished next week.
Bfeldman
Post by Bfeldman » Fri May 31, 2019 12:12 am
rarefish383 wrote:For some reason I was having trouble getting pics to post. My problem is my drive is over a mile and a half long with sevearl other farms drives off of it. I had to get the building manufacturer to see if they could get the building in. Then the local quarry is just a few miles away, just over the line in VA. They only have 4 trucks they can run into WV. WV requires "Apportioned Tags", and there trucks with them are quad axle dumps. He couldn't cross our cattle bridges. The guy that is doing the grading has the same problem. The only truck he can haul gravel on doesn't have Apportioned Tags. Finally found a WV guy that could do it, but he had to make two loads with his smallest truck. Then I had several trips to widen the drive from about 7' wide to 14' wide, the entire length of the drive. It will be all finished next week.
Sounds like a Royal PITA!
Post by TripleF » Fri May 31, 2019 9:46 pm
I just had this rehandled my our own muskrat man.....he thinks it's an old Snow & Healey. It's a Hudson Bay pattern for sure!
Can't wait to use it....
last pic is before I sent it to him!!
SCOTT
http://www.pocketknivesblog.com
https://gumroad.com/l/ZLDb
Post by doglegg » Fri May 31, 2019 9:49 pm
That is knice Scott. Muskrat man seems to be the axe guru. He sure does good work. Congrats. Better than a new one. ::tu:: ::tu::
Quick Steel
Post by Quick Steel » Fri May 31, 2019 11:12 pm
If there is such a thing as a handsome axe, yours fills the bill Scott.
"Life is good if you don't weaken." AG Russell
New_Windsor_NY
Post by New_Windsor_NY » Sat Jun 01, 2019 6:28 pm
Bfeldman wrote:New Windsor-That’s definitely a lineman’s Hatchet so it would make sense that your dad picked it up when he worked as a lineman. Stanley made a lot of them for Bell and I believe that those all have a Bell Systems stamp on the opposite side. I wonder if yours has a stamp on the reverse.
It is/was definitely stamped BELL SYSTEM. It appears that someone tried to "erase" it. You can still make out enough of the lettering to know what it says/said. I'm sure there's a good story in there somewhere. It's a shame I don't nor will I ever know what it was. ::dang::
Click To Enlarge.
(Original Post Near Top Of This Page)
Bfeldman
Post by Bfeldman » Sun Jun 02, 2019 2:47 pm
Scott-that’s a beauty. And looks a lot like the snow and neally that I’ve got (posted earlier in the thread)
New Windsor- that certainly does add to the mystery! Clearly someone wasn’t happy with Bell at some point.
Return to “Other Sharp Objects”
