Home built 2" x 72" belt sander project
- zed6309
- Bronze Tier
Re: Home built 2" x 72" belt sander project
Mike I'll be following this closely as I've wanted to improve my belt sander for a few years
Paul,
- Meridian_Mike
Hey everyone....
I am a little bit behind in my projects so this one hasn't moved in a while.
I have almost all the parts now so construction should start soon.
I will try to take pictures as I go so I can show my success (or failures).....
I do not have enough skills to create such a tool on my own and I think that it is not cost-effective, since it takes a lot of time and consumables. It seems to me that it is much easier to buy a finished product that will be guaranteed by the manufacturer. As a woodworker, I always choose quality sanders for myself, as these tools show the results of my work. All you have to do is visit this site and get the best recommendations for choosing a sander that meets all your conditions.ReidJustin wrote: ↑Mon Feb 15, 2021 8:00 am Hmm ... an Interesting scheme, but I'm not sure how good your sander will be. Usually, such tools are of high accuracy and quality, which is the main thing when creating such a tool.
Looks like a great start to the project.
Can’t wait to see it finished. Those hollow tool arms will vibrate. I filled mine with a 2x2 that is cut to fit and drove inside. That helped with vibrations.
- Meridian_Mike
Thanks for that advice Tony!
I can go ahead and do that from the start!
- Meridian_Mike
Yes, that thinking is true.
BUT... I have all the tools to do the drilling and welding and, I work at a steel company so the frame steel was free.
AND.... I just want to do it..... you know... The craftsman in me wants to "build my own".
Could you tell me some more information about it? Let’s talk in PMReidJustin wrote: ↑Sun Feb 21, 2021 12:16 amI do not have enough skills to create such a tool on my own and I think that it is not cost-effective, since it takes a lot of time and consumables. It seems to me that it is much easier to buy a finished product that will be guaranteed by the manufacturer. As a woodworker, I always choose quality sanders for myself, as these tools show the results of my work.ReidJustin wrote: ↑Mon Feb 15, 2021 8:00 am Hmm ... an Interesting scheme, but I'm not sure how good your sander will be. Usually, such tools are of high accuracy and quality, which is the main thing when creating such a tool.
- Meridian_Mike
Well..... it has been a while but I did find a few hours yesterday to start assembly of my belt sander.
I didn't take a lot of pictures but maybe if y'all want to try it, I can at least answer questions.....
Here is most of the pieces I started with......
I got a few pieces like the wheels and such from Origin Blade Maker.....
First thing I did was assemble the frame plates and set the hole for the tool arm so it would move in and out easily with as little slack as I could build in.
Then a good bit of work slipped on by before I took another picture....
I set up the pulley shaft and bearings, and put on the belt drive wheel.
I set the location for the upper wheel and bolted it on the upper tension arm.
I also set up the platform for the motor.
The next parts I put on were the backing plate and wheels and the mounting bracket for the platen.
SO..... with all the wheels in place, I had to load a belt on to see what this contraption was gonna look like....
I made a bracket for the tension piston and got it welded in place. My drill battery died so I figured it was time to call it a day.
Well on my way to having a "sure 'nuff" 72" belt sander!!
More to come when I can get back out there and finish up....
- Jeffinn
That’s looking really good Mike! Thanks for keeping us updated.
Jeff
Jeff
Hey … it’s a pocketknife for gosh sakes. I’m not selling the Mona Lisa….Bullitt4001
https://www.jfinamoreknives.com
http://www.secondlifeknives.com
- Meridian_Mike
Thanks Jeff!
- glennbad
That sure looks like it's coming along nicely!
- cudgee
Wow,Meridian_Mike wrote: ↑Mon Jun 07, 2021 3:05 pm Well..... it has been a while but I did find a few hours yesterday to start assembly of my belt sander.
IMG_7031.JPG![]()
- Meridian_Mike
Thanks!!
I hope I get a few minutes back in the shop this weekend so I can finish it.....
- cudgee
Hope so, and we all want to see some of your work.Meridian_Mike wrote: ↑Wed Jun 09, 2021 12:05 pmThanks!!
Have you anything to update on this project, Mike?
I have started collecting a few parts to make a 2x72 myself, and am very interested to see how yours turns out!
Jesus is life.
~Reverand
~Reverand
- Meridian_Mike
I haven't done a lot. I have been out is the yard with my wife helping her so no updates.
I did get my tool rest cut out. I have to get it bolted in place next. I will make sure to get some pics when I do.
